Discussion topic: Unhappy my broadband keeps failing
This message was authored by: Joeyfoff
For inexplicable reasons my superfast broadband keeps completely failing, my phone drops out of Wi-Fi and my sky dish tells me I have no connection... whenever I try and check it on the Sky app, it tells me that it checked it over four hours ago and it was fine then which is absolutely useless for now!
Re: Unhappy my broadband keeps failing
@Joeyfoff
It's nothing to do with a Sky dish.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Joeyfoff What are you seeing hub wise when you get the issue, the software check is just that but cannot do or explain much!. See the link below!. If you say what you have hub wise, may be able to guide further!
