6
This discussion topic has been answered Discussion topic: Was is Sky Broadband not available to my home yet is available to my neighbor's?
This message was authored by: Pembrae
I am looking to move to Sky broadband but the availability checker says its not available to my address. However, when I check other addresses on my street it says it is available, why is that? I am currently with Virgin Media and need to move as they are way too expensive. Thanks in anticipation.
Avatar for Pembrae
This message was authored by: Pembrae Answer
Re: Was is Sky Broadband not available to my home yet is available to my neighbor's?
@cookiemonsteruk
Thanks for the link, I will fill in the information and see what I get back.
@Pembrae
Are you saying sky isn't available at all fttp isn't
Could you enter your full address below and post the table and notes after removing you address from the image
Avatar for Pembrae
Hi @cookiemonsteruk , thank you for your reply. The information you requested is below.
@Pembrae
This is the form to fill in online where neighbours can get fttp but you can"t
In the drop down below what is your enquiry choose
"I can't get fibre but my neighours can" it can take them 2-4 weeks to respond
https://www.openreach.com/forms/fibre-broadband-availability---customer-form
@Pembrae
Unless you mean fttc which is on waiting list ie all slots at the cabinet are taken up . You would need to keep an eye on that link every couple of weeks until it shows avaiable and place your order with sky as soon as it is available
Avatar for Pembrae
@cookiemonsteruk
@Pembrae
The link is for full fibre. Which isn't available.  The waiting list at the end of vdsl shows waiting list which means someone has to cease their connection before your can apply . That will only happen when the first 2 rows become available
