3
This discussion topic has been answered Discussion topic: WPA3 Will not work with Ringdoor needsWPA2
This message was authored by: Ian2240
Thinking about SKY Max hub, be carefull.
we have a Ringdoor which is not compatable
with WPA3. Only WPA2 as I read it you can't set Sky Max to WPA2. The same might apply to Nest Thermostat and Sonos speakers. Needs further infomation from Sky, having tried its impossabe to find a person!
Re: WPA3 Will not work with Ringdoor needsWPA2
@Ian2240 no that is the control for the White Wifi Max hub.
@Ian2240 whatever you read was wrong you can change the Wifi security level on the white Hub6 in the My Sky app. Log in choose Broadband/Wifi Settings/ Advanced settings/Wifi Security and you will see the screen below choose WPA2 from the drop down.
Avatar for Ian2240
Level 2 icon
Good morning,
Thanks for that, but does that revert it to my WiFi  Black hub, if  so what is the advantage Max ?
