Discussion topic: WIFI KEEPS GOING DOWN
Message posted on 08 Jun 2024 07:37 PM
Message posted on 09 Jun 2024 07:17 AM
Re: WIFI KEEPS GOING DOWN
@Noddy44 the ligts in the hub will tell you if it is an external issue see https://www.sky.com/help/articles/hub-lights-explained-start
If your hub us losing the connection log onto the connection test in the My Sky app and click to run it dont rely on the info it gives intially. If the test detects a line issue it should offer to book an engineer to check the line if it doesnt give Sky a call.
Message posted on 09 Jun 2024 08:58 AM
Thanks Chrisee.
This explains it clearer.
Message posted on 09 Jun 2024 09:02 AM
I am experiencing the same issue in London Borough of Merton.
Message posted on 09 Jun 2024 07:39 PM
Spent over an hour trying to resolve the issue. According to Sky Technical it a security issue. Sky have set a high level not allowing WiFi, especially on Apple devices. Not happy when Sky say wall to wall fibre.
Message posted on 09 Jun 2024 07:56 PM
Unfortunately that doesn't really make sense: it's Apple which has its devices complain about wireless encryption lower than WPA3.
