Discussion topic: WIFI ISSUES
This message was authored by: Nasos1
WIFI ISSUES
Hi , a couple of days all my devises by wifi withheld hub have started to disconnect and re connect after a few seconds. I had the same problem before and I have replaced the old hub with a new one. Everything was alright, until couple of days ago. Also now the sky mini box disconnects as well for a few seconds.
Re: WIFI ISSUES
@Nasos1 if the issue is happening after a change in hubs it is likely something causing interferencecin your home. Could be from a neighbour's network if so a hub restart might help. However it could be from a piece of electrical equipment like a fluorescent light, microwave or just about anything but it is most likely in your home but if your neighbours havecthe same issue it could be outside.
Avatar for Nasos1
Re: WIFI ISSUES
Good morning,  the new hub works fine for a couple of months. Yesterday I have realized that the wired connections are having a problem as well not just the WiFi. All the lights at the hub are constantly green.
Re: WIFI ISSUES
@Nasos1 could be a line issue if the ethernet devices sre affected if you post your Sky hub's stats forum members should be able to advise see Find your Sky Broadband router statistics
