5
This discussion topic has been answered Discussion topic: WIFI Drops
This message was authored by: MM1424
WIFI Drops
My home wife drops at 3am to 5.45am everyday
Avatar for MM1424
This message was authored by: MM1424 Answer
Re: WIFI Drops
The setting was on Eco.
I have changed it to active.
Will monitor tonight and see if the WiFi goes offline.
thank you so much for helping me.
much grateful 🙏
Re: WIFI Drops
@MM1424
Do you have sky q?
Avatar for MM1424
Re: WIFI Drops
yes I do
Re: WIFI Drops
@MM1424
That would suggest the sky q eco mode may have to be changed
Follow the steps below and change eco mode to none
https://www.sky.com/help/articles/using-the-standby-settings#:~:text=Eco%20or%20Active.-,Eco,any%20s....
Avatar for MM1424
Re: WIFI Drops
much grateful 🙏
Re: WIFI Drops
@MM1424
much grateful 🙏
@MM1424
Hopefully that works 👍
