Discussion topic: Very slow WiFi
This message was authored by JimmyJDO This message was authored by: JimmyJDO
Very slow WiFi
WiFi has been very slow for over a week, sky checks online says there is no problem and have followed all the advice. None of it has helped
Re: Very slow WiFi
@JimmyJDOWhen you say very slow is this also in the same room as the Wi-Fi router? Or is this in other rooms in the property?
Could you please post your router stats following the link below.
JimmyJDO
Re: Very slow WiFi
In all rooms. I'm having to use data roaming at home on my phone as WiFi now so slow that webpages won't load
Re: Very slow WiFi
@JimmyJDOCould you post your router stats this will let us see the speed that you are getting. Also is the router in clear view with no obstructions around it?
