Discussion topic: Very poor internet connectivity
Message posted on 03 Jun 2024 01:56 PM
Message posted on 03 Jun 2024 02:06 PM
Re: Very poor internet connectivity
What form of Ultrafast broadband from Sky do you have? There's a known potential issue with Powerline and G.fast.
Message posted on 03 Jun 2024 02:15 PM
@TimmyBGood I have 'Ultrafast 1', which the app tells me is as good as I can have where I live.
The machine having issues connecting is plugged in to the router via a Cat5e cable, so I don't think the powerline extender would be a factor?
Message posted on 03 Jun 2024 02:27 PM - last edited: 03 Jun 2024 02:30 PM
With an Openreach ONT for FTTP, or with the Sky Hub connected to a telephone wall socket? The absence of higher speed suggests the latter, which would be G.fast.
G.fast broadband can be allergic to Powerline networking without any direct connection between the hardware: it's a side effect of injecting data signal into mains cable.
Message posted on 03 Jun 2024 02:33 PM
I think our internet arrives via the phone line from the pole outside.
The powerline extender is connected via a cat5e cable, same as the ethernet cable.
Could the powerline be causing interference? I think I will still be able to connect the second laptop wirelessly if I disconnect the powerline.
Message posted on 03 Jun 2024 02:37 PM - last edited: 03 Jun 2024 02:39 PM
Almost certainly G.fast, if there's no Openreach ONT in place.
I'd suggest trying without any Powerline adapters plugged in to any mains socket and see if it's then stable: that way you know where the issue is.
You wouldn't have encountered the same phenomenon with the previous Virgin connection because coaxial data transmission is fundamentally different to G.fast.
Message posted on 17 Jun 2024 10:38 AM
I've goven it a while to test during Teams meetings.
The connectivity is still very poor, even without the powerline adapter plugged in.
My WiFi connection is fine, as I am closer to the router.
At this point, we're considering seeing what the cancellation fee is like and going back to Virgin broadband 🤷
