2
This discussion topic has been answered Discussion topic: Using others wifi
This message was authored by: DODD83
Using others wifi
How can I block other people using my WI FI  I do not wish for unknown people to use my WI FI .
This message was authored by: Annie+UK Answer
Re: Using others wifi
Change you wifi password on your router
@DODD83 if you suspect other people are using your WiFi  because the hub lists devices as UNKnOWN you should becaware all that means is that the device is not reporting what is when the hub asks not who owns the device so it is quite likely to be something you own yourself.
