Discussion topic: PON Light flashing
This message was authored by: Stu8585
Message posted on 27 May 2026 10:00 AM
PON Light flashing
PON light flashing. Internet works fine in the morning then cuts out after a few hours and the PON light comes on. Tried restarting it several times with no luck
Find out more
Message posted on 27 May 2026 10:50 AM
Re: PON Light flashing
@Stu8585 the Passive Optical Network light indicates the ONT is receiving an optical signal, it flashescwhen thecsignalmis present but it hasn't locked onto data feed and is solid when it has. If the fault cintinues report it yo Sky as they need to get Openreach of City Fibre to check the fibre feed. I had a similar fault a few months ago which was sorted by changing the ONT.
