2
Discussion topic: Using Tp link ax1800 with Fiber to the home
This message was authored by Biggingus This message was authored by: Biggingus
Hello so I recently got fiber to the home (In Ireland) and need a router that that has more options than the sky provided router  so I got the TP link ax1800  this router  will not connect to the internet and I'm not sure what I'm doing wrong cany anyone help thanks
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty Answer
Re: Using Tp link ax1800 with Fiber to the home
@Biggingus
Pretty sure for Eire the authentication is PPPoA/E so slightly different.
Have a look at this link it may help with the settings you need.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
@Biggingus
Biggingus
Thank you @Skull+Treaty  so much you solved the missing peace the vlan was the issue and they talked about it in the post thank you
