3
This discussion topic has been answered Discussion topic: Using My Own Router - ASUS RT-AC86U
This message was authored by: Neil1310
Hi,
I've just had Sky broadband installed. Iy came with their home hub 6.
I'd like to use my own router so I have better WiFi cover in my house. My router is Asus RT-AC86U.
I'm unsure if I replace Sky's home hub with my router, or connect my router to Sky's built hub.  Also, any specific settings.
Is there a set up guide out there that I can use.
This message was authored by: cookiemonsteruk Answer
Re: Using My Own Router - ASUS RT-AC86U
@Neil1310
Whether to fully replace the sky hub with the asus depends on whether you want to use sky internet calls
Make sure asus is on latest firmware
If you are on full fibre in the uk then to replace the sky hub
Locate client identifier (option 61) and enter anything@skydsl|anything
@Neil1310
Avatar for Neil1310
Thanks @Cookiemonster
Avatar for Neil1310
Thanks @cookiemonsteruk
