Discussion topic: Upgrade Wifi Max - booster comparability?
This message was authored by: Gemma0880
Hi
We have just upgraded the router to a white MAX - signal is poor in areas -👎
We have a sky booster SE210A I have managed to connect it into the network but we can't connect 😩 is it incompatible and can this be meshed so wd dont have to change SSID everytime (if we could actually connect) been inyk the settings and got the password as well 👍
Any ideas how to get the poor reception rooms better?
Re: Upgrade Wifi Max - booster comparability?
@Gemma0880 The onlyextenders that can create a mesh with the Sky Max hub are the ones thst come as part of the wifi Max bundle see https://www.sky.com/help/articles/sky-wifi-max
Avatar for Gemma0880
Hi
We pay for that sobthats good will have to send them an email 👍
@Gemma0880
Email won't work: you'd need to phone.
Will ring them Friday 👍👍
