4
This discussion topic has been answered Discussion topic: Broadband not working
This message was authored by: Mandy16
Broadband not working have been through settings etc and switching off and on still not working???
Re: Broadband not working
@Mandy16
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
@Mandy16
This message was authored by: DJClash
I'm having similar issues with mine. WiFi keeps dropping out and coming back. Service checker says no faults and everything is as it should be
@DJClash
Have you followed the steps in post 2?
Avatar for Mandy16
Thanks all sorted now
