24 Jun 2022 07:44 PM
Ever since I renewed my contract about 2 weeks ago, I have noticed the rapid decline in my broadband speed. I keep getting errors on my LG Smart TV saying my connection is too slow, making it impossible to watch Netflix and Disney+, even just a video from youtube stops and the sound keeps going on and off. It's been dreadful. I regret taking Sky again. I have the same problem on my laptop.
24 Jun 2022 07:45 PM
Also I would like to add that nothing has changed at all in our installation for the past 2 weeks either.
24 Jun 2022 07:49 PM
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
24 Jun 2022 08:30 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 24911890 42770445 0 1298280 22113935 48:51:31 LAN Up 136484555 43673790 0 21738336 1458576 423:13:59 WLAN (2.4 GHz) Up 18462807 9958455 409 29192 3670 423:12:22 WLAN (5 GHz) Up 172726314 97171725 0 4173186 0 423:12:09
25 Jun 2022 09:52 AM
The speeds look good but there was a line drop 48 hours before you posted. Neither of which are regarded as a line drop.
Did you keep the same hub or did they upgrade that?Did you have any sky booster boxes?
25 Jun 2022 09:56 AM
I didn't upgrade and they didn't send me anything new, it's just been renewed but I have the same equipment
25 Jun 2022 09:57 AM
I don't have a sky booster box
25 Jun 2022 11:12 AM
I noticed wan mer was downloading at 22Mbps via ethernet. Was this the tv ? Is that connected via ethernet? Does it happen on wifi devices as well?
If you could look at the ends of the ethernet cable is the a cat. Number on the sleeve are all 8 pins on the plug wired?
If only 4 pins are wired then you will need to log back onto the hub and go to ethernet along the top and make sure that it is showing "fast" not "gigabit"
if all 8 pins are wired ie its cat.5e gigabit or above then keep it at gigabit
27 Jun 2022 01:17 PM
so I checked and yes it's cat.5e gigabit
27 Jun 2022 01:21 PM
and yesterday it happened again with the sound cutting when watching from Disney+ on the tv, with no other devices using the internet, we were all in the living room trying to watch a movie and we got a messaged on the screen saying our internet connection is slow
27 Jun 2022 01:22 PM
These are today's stats:
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 51593806 88554974 0 0 0 113:43:45 LAN Up 50059952 32368554 0 0 1 488:06:13 WLAN (2.4 GHz) Up 20738501 11007599 409 0 0 488:04:36 WLAN (5 GHz) Up 201066752 114605832 0 2 0 488:04:22
27 Jun 2022 01:28 PM
Is the tv connected directly to the hub by ethernet or via powerline adapters. Your first hub stats showed speeds of 24Mbps via ethernet which is enough to stream uhd and still have 50Mbps to spare
27 Jun 2022 01:32 PM
it's plugged in directly to the sky hub
27 Jun 2022 09:29 PM
I have tried with a cat7 ethernet cable and no change.
The tv via the Sky Q box works fine, it only happens when streaming from Netflix, Disney+ and Prime video, but the sounds cut off every 30 seconds or so. It started recently about 2 weeks ago. We never had that issue before, we didn't change anything, the TV is a smart LG TV that we got about a year ago, the Sky Q box and the Sky Hub are still the same, nothing has been moved either.
