Discussion topic: Unable to call Sky
Message posted on 21 Aug 2025 03:44 PM
Unable to call Sky
Hi,
I received the following text: "Hi. Sorry but there's an issue with completing your Broadband and Talk order. To get up and running, just give us a call on [removed number to post message]."
I tried calling the number but it is unavailable. The same goes for other contact phone number I found speaking with the web assistant bot (not mentioned as couldnt post then). I am calling from aboard and added international minutes specifically to call, as I wasnt going anywhere dealing with the web assistant bot - I had hoped it would eventually connect me with a person. I assume there must an issue connecting to the phones from abroad then..
In "My Orders" there doesnt appear to be any issue with the order, so I am unsure what the text is referring to. Does anyone know whats up or can anyone from Sky give me a call, or reach out if there is an issue?
Thanks,
Michael
Message posted on 21 Aug 2025 03:51 PM
Re: Unable to call Sky
No one will / can phone you. Your Community tag name isn't linked to any Sky accounts you have or have applied for.
You may struggle to call Sky from abroad.
These are the other current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
