Discussion topic: WiFi connection to fire stick
Message posted on 21 Aug 2025 02:49 PM
The connection to the fire stick is 'poor' and we are unable to watch tv with it.
Message posted on 21 Aug 2025 03:00 PM
Re: WiFi connection to fire stick
@Caroline142 You would be advised if possible to Ethernet adapter and connect the Firestick that way, only you can say if that is possible to do.
Message posted on 21 Aug 2025 03:14 PM
Thanks...how would I know if that is possible? Where would I get one from? Thanks
Message posted on 21 Aug 2025 03:20 PM
@Caroline142 not sure about an etgernet adapter but moving yhe firestick from behind the TV using a HDMI extender cable often helps as TVs block a lot of the WiFi signal - Amazon sell these.
Message posted on 21 Aug 2025 03:24 PM
Thank you, will give it a try!
Message posted on 21 Aug 2025 03:26 PM
@Caroline142 Also to go with @Chrisee recommendation, the adapter link!. Do check out if there is a Ethernet cable included and if it will be long enough!
Message posted on 21 Aug 2025 03:30 PM
Thank you! Hopefully we will get it sorted one way or another!
