Discussion topic: Ubiquity Access Point Dropping Out From Sky Router
This message was authored by: adrem7
Recently switched to Sky but the access points around my house are dropping out. Not sure why, but I'm pretty sure the access points aren't damaged. I can see in Sky router logs that they drop out but I need some direction on where to go with that.
Sky Router info:
Model SR203
UniFi AC Info:
One device connected using PoE
UAP-AC-Pro
Has worked with Vodafone router and service so know hardware is fine.
Haven't tried different router with Sky service.
Sky Router Logs:
https://docs.google.com/document/d/1a9t4mnFwNJQWkfMOj9muazI5vnFvfoxFuZ9tEbLbyUc/edit?usp=sharing
Re: Ubiquity Access Point Dropping Out From Sky Router
@adrem7
The Sky hub is very temperamental when it comes to ethernet cables & manager switches so if you are using a managed PoE Ubiquiti switch this could be the problem. Additionally the hubs do not like cheaper ethernet cables that dont have all 4 pairs wired up so check your cables and trial it with a new one.
I am NOT a Sky Employee
