Discussion topic: WiFi keeps dropping and reconnecting
This message was authored by: Abdulrahim
The WiFi will at random turn off and start flashing orange then the light will turn off completely then eventually in a random amount of time turn back on his has been going on for around 24 hours and is extremely annoying any help or communication would be much appreciated.
Re: WiFi keeps dropping and reconnecting
@Abdulrahim Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for Abdulrahim
It says it looks good even when it's not working
@Abdulrahim pleae post your hub's stats see Find your Sky Broadband router statistics
Router Statistics
System Up Time: 02:07:52
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 523418 612634 0 66651 193600 02:03:23 LAN Up 557026 475816 0 38956 37158 02:07:52 WLAN (2.4 GHz) Up 92270 55245 0 600560 45275 02:06:06 WLAN (5 GHz) Up 18940 2706 0 708 0 02:06:04
Broadband Link Downstream Upstream Connection Speed 49000 kbps 14993 kbps Line Attenuation D1(13.0 dB) , D2(26.1 dB) , D3(40.3 dB) U0(0.8 dB) , U1(21.1 dB) , U2(30.1 dB) Noise Margin 9.1 dB 9.2 dB
Hi @Abdulrahim
You do look to have a line fault it would be best to call Sky about it and claim you are getting lower than expected speeds & its dropping out
I am NOT a Sky Employee
