3
Discussion topic: Trying to turn off Wifi for LAN use only
This message was authored by randomer03 This message was authored by: randomer03
I want to turn off my wifi signal from my router so that Im only using the cable. Ive followed the instructions to do so and typed in the number in the seach bar and now it's asking me to enter my username and password before I can go ay further.  But WHAT username and password?  My SKY details arent being accepted, and computer admin details arent being accepted.  What are they asking for? Have attached an image.pass.jpg
This message was authored by Eeeps This message was authored by: Eeeps Answer
Re: Trying to turn off Wifi for LAN use only
You are trying to access the Web Administration pages of your router (which is correct) but it has it's own credentials (username and password).
There are three different types of hub and they have different credentials.
Read the following link to determine what to use
Logging into Router
p.s. I suggest you change the password for the router to help improve security (make sure you remember it)
Logging into Router
randomer03
Ok thanks, I managed to login.  I disabled wifi (wifi access point, I think that was the correct option?) but the wifi light is still on the router.  Does that mean the wifi is still producing a signal? Shouldnt it be off now?
randomer03
I ve just realized i only turned off one of the two wifi signals.  Have got it all sorted now, thanks for your help 🙂
