Discussion topic: Trying to connect
This message was authored by: keithg37
Message posted on 11 Dec 2025 03:34 PM
Trying to connect
Trying to connect my ps5 to WiFi but not connecting
Find out more
Message posted on 11 Dec 2025 04:44 PM
Re: Trying to connect
@keithg37 where a device can see the network but wont connect first check you are entering the passcode correctly and not misreading a number like 1 or 0 for a letter O or I or vice versa which is easy yo do. If you aren;t reboot the PS5 as it can have an issue with the memory location being unable to over write a previous password in a few cases you msy need to reset the PS5.
