Discussion topic: Internet down (no light on router) and voice light is orange
This message was authored by: Hflinton
Hi, we can't get our internet to work despite the checks on this app saying it's ok. We've tried turning on and off to no luck.
Re: Internet down (no light on router) and voice light is orange
@Hflinton
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
