Discussion topic: Trying to connect to internet
Message posted on 07 Nov 2024 01:44 PM
" check if you have configured deny list or firewall settings on your router, which might block the tapo device"
Trying to connect a camera to my WiFi, can someone please advise on how to do the top? Thanks
Message posted on 07 Nov 2024 01:52 PM
Re: Trying to connect to internet
Do you have a white or a black Sky Hub?
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Message posted on 10 Nov 2024 04:31 PM
Hi sorry all sorted now thankyou !
