This discussion topic has been answered Discussion topic: Transfer from Virgin to Sky
Message posted on 13 Feb 2025 08:31 PM
We are currently with Virgin, out of contract, and are thinking of moving to Sky.
we did have a BT landline but haven't used that for a number of years so not sure if the connection is still 'live'
We do have concerns as to how straightforward transferring to Sky would be if the BT line is no longer working, particularly if it might involve digging across the front garden.
Any help/thoughts would be greatly appreciated. Thank you
Message posted on 13 Feb 2025 08:55 PM
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 13 Feb 2025 08:49 PM
Re: Transfer from Virgin to Sky
If you’re in a fibre priority area they won’t let you use that line anyway. Openreach will insist on putting full fibre in as the intension is to phase the old copper lines out. Also, if you do go back to using that you’ll find the speed a very big drop from Virgin.
Message posted on 13 Feb 2025 08:59 PM
Many thanks for speedy reply
Message posted on 13 Feb 2025 09:00 PM
Many thanks will do
