Discussion topic: WiFi not working
Message posted on 20 Jun 2025 12:15 PM
WiFi not working
Message posted on 20 Jun 2025 12:19 PM
Re: WiFi not working
After running the service checker click on your broadband speed and click test my connection inside the blue box to update the previous test results
Message posted on 20 Jun 2025 12:20 PM
@Steve103
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
