Discussion topic: Text from sky
Message posted on 10 Apr 2024 10:38 AM
Text from sky
I recieved a text from sky asking to confirm my broadband and talk order address,it said to reply if details were correct ,I did but won't send.
i don't think it's a scam as I have recently ordered a new broadband package.
any help would be appreciated.
Message posted on 10 Apr 2024 10:48 AM
Re: Text from sky
@codan11 If you are unable to send a response then give Sky a call, you can find the number to call at the bottom of the link below under " Need more help ".
Listen through the voice prompts and ignore it if and when it sends you a text to stay on the line to speak to an advisor.
Message posted on 10 Apr 2024 11:29 AM
Re: Text from sky
Thanks for the reply.so does this look legit to you ?
Message posted on 10 Apr 2024 11:51 AM - last edited: 10 Apr 2024 11:53 AM
Re: Text from sky
The image was rejected as you didn't block out the senders mobile number. If you're not convinced it's from Sky give them a call as suggested and I'd be wary of clicking on the link that's mentioned.
Message posted on 10 Apr 2024 11:54 AM
Re: Text from sky
Thanks @Daniel0210 .
i didn't click on any link,what link do you mean?
I'll repost pic with number blocked out
Message posted on 10 Apr 2024 11:58 AM
Re: Text from sky
My mistake. I've just viewed the original image again. I'm off to Specsavers 😂
