Discussion topic: Terrible connection
Message posted on 25 May 2025 01:28 PM
Terrible connection
My wifi for the last 3 days keeps dropping out. Keep having to reset it. Is there something going on in the nearby area?
Message posted on 25 May 2025 01:37 PM
Re: Terrible connection
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 25 May 2025 01:49 PM
@Lissfx Where is the nearby area?
Message posted on 25 May 2025 01:51 PM
S25 sheffield
Message posted on 25 May 2025 01:59 PM - last edited: 25 May 2025 02:04 PM
@Lissfx Looks like nothing going on have you looked with the service checker for your account? Use @caesarome to test. also below should you need.
Message posted on 25 May 2025 02:04 PM
I have unplugged it all again. Waited and plugged back in. Its back working again but for the last 3 days it has dropped out several times a day. I usually have no issues. Not sure what is happening.
Message posted on 25 May 2025 02:07 PM - last edited: 25 May 2025 02:09 PM
@Lissfx When you have the problem is the hub showing you any light's changing? Not going to keep trying to pull the information from you forever, we are customers like you trying to help you with your problem, you are not talking with sky.
Message posted on 25 May 2025 02:12 PM
I appreciate your help and guidance. Thank you.
yes its usually green, orange, green orange across the 4 lights. If it goes down again, ill contact sky. Thanks again
Message posted on 25 May 2025 02:19 PM
@Lissfx The hub is showing with that light sequence that there is a problem, no Internet is available, it can be for a good few reason's, a few test's were suggested but if you wish to do the call sky then that will work, have them run the test on your line....
