Discussion topic: No broadband
This message was authored by: GaryB7
No broadband
My broadband is not working
Re: No broadband
@GaryB7
For a broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
