Discussion topic: Tech support?
This message was authored by: Tinamac1983
Tech support?
I was put over to a Tech Support re a problem I had about reconnecting my house phone......unbeknownst to me I have been charged £35.00 for nothing, as the help I had was from an actual Sky employee at the time....the phone should have been connected at the time the fibre was installed.
Re: Tech support?
@Tinamac1983
Your post isn't very clear, what is the £35 charge for?
The landline connection can take 24 hours or so to become fully operational after the broadband is activated.
Re: Tech support?
@Tinamac1983
A call to Sky shouldn't see you being charged £35 so how did you find the numbner to call them on ?
The phoen connection should plug into the back of your broadband hub so have you tried this ?
Re: Tech support?
@Tinamac1983 is the charge on your Sky account or your phone bill? If the latter you have inadvertently used a call forwarding service using a premium rate number to contact Sky. Sky's direct support numbers all start 03 and are charged as normal calls or are free if dialled from a sky talk or sky mobile line.
