Discussion topic: WiFi light amber,
This message was authored by: amandap138a
WiFi light amber,
So my lights on my WiFi hub, is green, amber, green I have tried everything suggested, unplugged, replugged, reset but it's still the same. Anyone gave any suggestions?
Re: WiFi light amber,
@amandap138a
The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
▪️I AM NOT A SKY EMPLOYEE ▪️
@amandap138a if yhe amber light is the one labelled as internet the issue is likely an external fault. Run the service checker in the My Sky app to see if it tells you Sky are already awarecof a fault affecting your line if they are you will havectonwait until it is fixed. If they arent then call them to report the ptoblem so it can be checked out.
