Discussion topic: Teams call dropping out
Message posted on 11 May 2026 07:01 PM
My teams calls are consistently dropping out, even when sitting right next to router
Message posted on 11 May 2026 07:39 PM - last edited: 11 May 2026 07:51 PM
Re: Teams call dropping out
@RKEARNS wrote:My teams calls are consistently dropping out, even when sitting right next to router
Not sure how much help this is but, so do mine and I don't have Sky Broadband!
Is anything else having problems or just Teams? Is it up to date? Assuming this is a work machine, do you use a VPN? Are you connected via WiFi? What happens if you use Ethernet?
Teams is an absolute 💩 platform, it genuinely could be it that is the problem.
Microsoft also provide some troubleshooting tips here.
