Discussion topic: TeamSpeak 3 not working
This message was authored by: Melchett1
I am failing to get TeamSpeak 3 working.
I have port forwarded the required ports for Teamspeak 3 per the instructions in https://helpforum.sky.com/t5/Broadband-Talk/How-to-set-up-port-forwarding/ba-p/2662260
However, the ports are still not open. I have double checked that my PC firewall allows the permissions.
Additionally, I can log into Teamspeak when using 5g on my phone but not when using wifi.
This message was authored by: Lisa-P1987
Re: TeamSpeak 3 not working
Lisa - Sky Tech Team Expert
Hi @Melchett1
Just to clarify, are you trying to run a TeamSpeak server or are you just trying to connect to one? You should only need to port forward if you are hosting one.
I am NOT a Sky Employee
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
This message was authored by: Richard123
Have the same problem, im trying to connect to a server, when switched to Sky afte that not able to connect
