Discussion topic: Zscaler and Sky Fibre
Message posted on 24 Mar 2025 03:24 PM
I've only recently upgraded to full fibre but I am having issues in my work laptop when working from home.
After lots of googling and support from work IT department I've established it's an issue with Zscaler not liking Sky Fibre (or vice versa).
what I can't establish is what the solution is but I'm hoping some kind folk on here will be able to assist?
Message posted on 24 Mar 2025 03:25 PM
Re: Zscaler and Sky Fibre
I should've added that it's preventing me from accessing VPN, some websites and work apps.
Message posted on 24 Mar 2025 03:31 PM
Do you have the white sky max hub?
If so it could be map-t ipv4 address sharing which needs changed to a 1:1 sharing
Message posted on 24 Mar 2025 03:32 PM
No, it's the sky broadband hub
Message posted on 25 Mar 2025 05:23 PM
Don't suppose anyone has any idea what this issue may be?
Sky seem to think it's not their issue as I don't have the Wi-Fi max hub... although the issue only started when changing to sky fibre...
Message posted on 25 Mar 2025 06:29 PM
Have you switched off Sky Broadband Shield (or at least set it to 18)?
Message posted on 25 Mar 2025 06:45 PM
Yes, shield is disabled
Message posted on 27 Mar 2025 09:33 AM
@ScottJones1
I know you don't have a Sky Max hub but can you still request to be removed from MAP-T by using the form on this post its worth seeing if this fixes the issue
Message posted on 27 Mar 2025 10:14 AM
Thanks, I did exactly that a couple of days ago and also had a call with Sky. They are sending out a new hub in the hope that might resolve the issue... let's see!
