2
This discussion topic has been answered Discussion topic: Tapo smartplug
This message was authored by: Bf8
Tapo smartplug
Tapo smart plug will not connect to sky max hub
Avatar for Bf8
This message was authored by: Bf8 Answer
Re: Tapo smartplug
I have found solution by reverting to password from previous sky box.
Re: Tapo smartplug
@Bf8
You may need to temporarily disable 5ghz on your Sky hub and/or change the security encryption method to WPA2 rather than WPA3. All these settings can be changed on the My Sky app under advanced WiFi settings for your hub.
I am NOT a Sky Employee
Avatar for Bf8
Re: Tapo smartplug
