Discussion topic: TLS/SSL Stripping Risk
This message was authored by: RedK84
My antivirus network inspector is showing that my sky broadband is at risk from a "man in the middle" - TLS/SSL attack and that the best fix is a firmware upgrade - I cant get anywhere with an assistant on resolving this problem - how do I fix this threat as it makes any device wiuthout a VPN unusable
Re: TLS/SSL Stripping Risk
You're the second person to report this recently, but it's perhaps worth noting that AV products can tend to  seriously overstate such risks in order to justify their own existence.
For any current* Hub model, updates are pushed out by Sky: there aren't any user-applied downloads.
That's extremely unlikely unless you've seriously upset a hostile state security agency or similar adversary: for such a vulnerability to be exploited the attacker needs to be either in wireless range (and convince you to join a bogus WiFi network) or actually within your own cabled network perimeter.
* In-support models are the Sky Broadband Hub, Max Hub and Gigafast+ Hub.
Theoretically the Q Hub has just gone out of support.
Which AV product is this?  It helps to know, so that Sky has the option to liaise with the company which produces it.
Avatar for RedK84
Hi,
Thank you - this is really helpful
It's AVG though a guest uses Nord and it flagged on their mobile too.
On my desktop Antivirus things are appearing OK but I am now quite nervous that this is more than a false positive on a mobile app
Cheers
Steve
This message was authored by: Stacks02
Hello,
I have received the sane notification via my AVG wi-fi scan.
I am less concerned now that this is being reported elsewhere.
GC
This message was authored by: Hayley1614
Hacking
My avg saying that theres a man in the middle on my Internet plus I've just gone onto pay for something and comes up with malicious site but it not sone one trying to hack in
This message was authored by: Sharcuk
Re: Hacking
@Hayley1614 There was a forum post last week on the same subject, I don't know if it helps!
https://helpforum.sky.com/t5/Broadband/TLS-SSL-Stripping-Risk/td-p/5192792
Sky Q, 2 mini boxes, booster and full fibre gigafast. Good WiFi coverage throughout a 4-bedroom house!
Re: Hacking
Perhaps worth noting that 'at risk' is very different to there actually being a hostile action in progress.
