Discussion topic: Sky pod max help
This message was authored by: Daisy411
Sky pod max help
My sky pod max light keeps flashing, when first plugged in and then it stops for a few seconds, and then the light turns back on, disconnected from my WiFi box, I have even used a Ethernet cable to see if that would work. But I still get the same result, any advice I would be most greatful
