Discussion topic: Switching to sky with own mesh already setup
This message was authored by: Syp363
I'm looking to switch my broadband services to sky to go with my tv.
i currently have BT and use an asus XT8 mesh system. Might sound like a dumb question but given I've got so many devices including ones like security cameras which are in the loft (hard to get to) set up, how easy is it to switch provider?? Is it as simple as changing a setting once sky is live??
thanks!
Re: Switching to sky with own mesh already setup
@Syp363
That asus will work with sky and has been proven to by a few people here
In the uk you will need to remove pppoe authentication used by bt and enter in client identifier (option 61)
anything@skydsl|anything
Avatar for Syp363
So just switch the pppoe. On the phone line the person didn't know if I needed the sky router.
I assume I change the network name and passwords back to what I have now so all devices will automatically connect?
@Syp363
What connection do you have fttc superfast or fttp ultrafast?
If you don't want to use your sky landline then you can directly connect the asus to an fttp ont or existing fttc vdsl modem or if you want to keep your sky landline then change the operating mode to access point.
Also if your have a lot of devices then you can change the ssid and wifi password to match your sky hub but as you are moving from bt you'd probably need to change them on you devices anyway
Avatar for Syp363
It's FTTP, was locked into BT due to it being a new build at the time.
currently don't use my bt hub at all. I'm trying to weigh up switching and saving vs the hassle of connect all the smart devices again - some of which were a real pain to get to work in the first place
@Syp363
If you continue using the Asus system when you switch to Sky then you wont need to reconnect all your smart devices.
I am NOT a Sky Employee
