Discussion topic: Switched from ee - issues activating sky broadband
This message was authored by: Ijmaunder
I Switched from EE, my  order stuck on KCI 3, so Sky cancelled it. However, the Openreach ONT box has a solid green PON light and is fully active. Sky have cancelled the order and I now need to wait to reorder at 2 30pm. What is to stop this happening again?  Do I need  a Community Escalation to Tier 2 to rebuild the order  as it is on an active  line.?
Any help much appreciated.
Re: Switched from ee - issues activating sky broadband
@Ijmaunder if City Fibre have cables passing your home Sky will use that network rather than re-using the Openreach connection is that a possible explanation. That would require a new fibre line and fitting a second ONT rather than a simple seitch if just using the Openreach ONT.
Could thst be the problem?
