Discussion topic: Red light on los
Message posted on 25 Aug 2026 09:43 AM
Red light on los
when I connect to wifi on my phone it says somethings wrong comes up with 3 things to click to let's try and fix still not working
Message posted on 25 Aug 2026 09:54 AM
Re: Red light on los
@Mozzle93 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If your ONT shows a Red Light please see this guide https://helpforum.sky.com/t5/Broadband-Talk/Can-t-connect-to-broadband-and-have-a-red-light-on-your-...
@Mozzle93 if the ONT has a red LOS light it means it is not receiving an optical signal. This can be a break in the fibre connection or a problem at the exchange but if the fiibre cable is securely plugged into the ONT these is nothing you can do it requires an engineer to becassigned.
After up to an hour the online Service Checker in the My Sky app run overca mobike connection should pick up the problem and can book an engineer saving a long phone call.
