Discussion topic: Sudden packet loss while gaming
This message was authored by: Sabi_T
When i game i am facing sudden packet loss for brief seconds and then it goes normal again. But it happens quite a few times in the game session which is very annoying
Re: Sudden packet loss while gaming
Hi @Sabi_T
What device are you gaming on and how is it connected to your Sky Hub? (WiFi or ethernet?)
I am NOT a Sky Employee
Avatar for Sabi_T
I play Dota 2 in pc. My pc is connected via wifi.
@Sabi_T If you can at least try with an Ethernet connection to rule out the wireless Wi-Fi side that would help.
Avatar for Sabi_T
Needed a long ethernet cable. Got it now. Problem solved. Cheers mate!
