Discussion topic: Streaming issues
Message posted on 08 May 2025 07:46 PM
Streaming issues
Can't stream TV and Microsoft teams calls connection is very poor
Message posted on 09 May 2025 07:23 AM
Re: Streaming issues
@Paul605 sounds like poor wifi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
