Discussion topic: No access to wifi
This message was authored by: Joshua124
No access to wifi
WiFi not connecting to devices
Re: No access to wifi
@Joshua124 is this all devices or just devices in rooms some distance from the hub? If the latter sounds like you need a better wifi set up. If the former then call Sky as there coukd be a fault.
