Discussion topic: Splitting WiFi bands on Sky Max Hub
Message posted on 23 Jan 2024 05:00 PM
I need to split the WiFi bands so that some devices connect to the 2.4GHz band rather than the 5GHz band. The device becomes unstable when connected to 5GHz. I can see there's advice for other Sky router but not the Max Hub. Grateful for any help.
Message posted on 23 Jan 2024 05:02 PM
Re: Splitting WiFi bands on Sky Max Hub
There is an option via your my sky app to disable 5ghz temporarily before re enabling it
Message posted on 23 Jan 2024 05:06 PM
@cookiemonsteruk thanks for the reply and forgive my ignorance but if I disable the 5GHz and then enable it won't the problem device try to connect back up to this at at some point? If I could rename the 2.4GHz band I can make sure it stays on that.
