7
Discussion topic: Splitting 5Ghz and 2.4
This message was authored by Joe+McG This message was authored by: Joe+McG
Hi,
Hope someone can help me.
I recently upgraded my bradband to 5G. Some of my devices will only work with 2.4 so I have attempted to log in to see if I can split however am stuck with Username and Password. Tried to do some research and tried to use "admin" as username and then the router password but this did not work.
Tried to contact Sky for support but unable to contact by phone or get any technical support on chat at all. Have been with Sky for many many years, rarely had a question but the last time I did I was able to use chat and phone. Not a change for the better!  many Thanks
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Splitting 5Ghz and 2.4
@Joe+McG
Does it allow you to override that message . You are only using it on your home network and no info goes past the router
@Joe+McG
What 5g hub are you using?
Are you on a sky sim?
Joe+McG
@cookiemonsteruk
No Sim and router model is SR203
@Joe+McG
Ah, 5g broadband is a different kettle of fish
Are you on ultrafast ?
Username admin
Password  12 character wifi password (case sensitive)
@Joe+McG
Full instructions to seperate wifi bands
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Joe+McG
@cookiemonsteruk
Tried using instrucitons, admin as password and then router password but no luck.
message says "Your password will be sent unencrypted"
@Joe+McG
Joe+McG
@cookiemonsteruk
That worked, thank you so much
