Discussion topic: Speed wifi
Message posted on 25 Feb 2024 08:48 PM
Speed wifi
Speed to hub is good but not getting the same speed to the wifi devices
Message posted on 25 Feb 2024 09:13 PM
Re: Speed wifi
@Taylor1984 wifi speeds will inevitably vary as the signal is affected by the.layout of your home, its type of construction and the level of interference. There are things you can do to help,things like making sue the hub is out in the open not hidden on the floor and rdbooting it somit finds the least congested channel. However like many others if you want fast wifi through out your home you will need more than thecfree hub Sky provides.
Sky sell their wifi max system at £7.50 a month which can otovidecup to 3 extenders assuming one of tgeir engineers agree you need them. Alternstively you can buy third party whole home mesh systems.
Message posted on 25 Feb 2024 09:34 PM
Re: Speed wifi
Thanks. I have approx 200mb to the hub, supposed to be 400mb guaranteed. I am using deco mesh system and I'm only getting approx 30mb to 60mb to my wifi devices .
Message posted on 27 Feb 2024 12:47 PM
Re: Speed wifi
You need to test with an ethernet connected device connected directly to the Sky hub first.
