Discussion topic: Speed test
Message posted on 03 Jun 2024 09:27 PM
Speed test
On my sky app it claims that i am getting 152mbs daily , the wifi keeps cutting out and i have to keep resetting router , ive also run soeed tests tonight on okta and 5 times it states i am only getting 80mbs
Message posted on 03 Jun 2024 09:40 PM
Re: Speed test
@Chinamc123 how is the device running the speed test networked? If its over WiFi the test is likely to be simply showing the Wifi speed in your home not the speed to the hub which is what the Sky test shows. Only test runs under controlleded conditiond can really be relied on these are the device networked using a gigabit Ethernet conection with nothing else using bandwidth.
Message posted on 10 Dec 2024 02:10 PM
Re: Speed test
Just had an engineer from open reach at my GFs. Same issue. Turns out the lan was into 1 on the router where it's 4 that the LAN goes into. Could be worth checking.
He had to reset the tmrouter after it.
Now getting 130-160 mbs
