Discussion topic: Smart Bulb connection
Message posted on 09 Jun 2026 04:45 PM
Message posted on 09 Jun 2026 04:58 PM - last edited: 09 Jun 2026 05:08 PM
Re: Smart Bulb connection
By default all current Sky Hub models broadcast the same SSID on both 2.4Ghz and 5Ghz simultaneously: this causes issues with some client devices.
One tip is to temporarily disable the 5Ghz band before running through the device setup procedure.
Message posted on 09 Jun 2026 05:24 PM
Thanks. How do I temporarily disable the 5Ghz band?
Message posted on 09 Jun 2026 05:27 PM
If it's a white Hub, that's done in the My Sky app.
Black Hub models are administered through their onboard browser interface.
Message posted on 09 Jun 2026 05:29 PM
Assuming that I have no technical skills at all. What or where is the 'onboard browser interface'?
Message posted on 09 Jun 2026 05:34 PM
https://helpforum.sky.com/t5/Broadband-Talk/Accessing-your-router-settings-page
