Discussion topic: Slow wifi
Message posted on 29 Aug 2025 04:37 PM
Slow wifi
Message posted on 29 Aug 2025 05:16 PM
Re: Slow wifi
@morantmaria Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 25 Sep 2025 09:19 PM
Re: Slow wifi
Message posted on 25 Sep 2025 09:42 PM
Re: Slow wifi
@morantmaria Is the TV connecting to the sky Hub via a wireless wi-fi connection? If so and that is fine, then there is a missmatch signal between the Hub and your mobiles, that can be any number off issues! Would be better to say what all the devices are, hub, phones etc!
Message posted on 25 Sep 2025 09:45 PM
Re: Slow wifi
@morantmaria wrote:
The costumer support told me than i have enogh Signal but is not true..my móvil and my husband phone we dont have wifi why ?
Do you have a strong working signal if your phone is next to the hub?
If yes, then you need to follow the suggestions given by @Chrisee
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £31 pm (till October 2026)
2 x FTTP lines: Digi £15 pm 900/900 & Aquiss £36pm 80/20
Connected in dual WAN to 3 x Asus XT9 mesh & 2 x Asus RT-AC58U
65" Samsung S92C OLED TV
6 other streaming TVs
