Discussion topic: Slow wifi
This message was authored by Roy1982 This message was authored by: Roy1982
Slow wifi
Since upgrading my skyQ to UHD my Wi-Fi is terrible. It works fine for TV service but connecting devices such as phones just won't load anything at all. I have my broadband stats, unfortunately it means nothing to me if someone has any advice I would appreciate it
thank you
Re: Slow wifi
@Roy1982  Notice that you have not re-bboted your router for the past 44 days. But can see that you had a drop in your connection 25 days ago, was this when you started to have issues?
Roy1982
Re: Slow wifi
Yes it probably is about that time.
Re: Slow wifi
@Roy1982  You could try re-booting the router to see if this helps with the issue. Just monitor the situation to see if it is still the same.
Roy1982
Re: Slow wifi
@Highlinder what would you recommend please?
Re: Slow wifi
@Roy1982The router needs a re-boot to see if that does sort out your connection problems.
