Discussion topic: Slow unreliable connection
Message posted on 10 Jul 2024 01:52 PM
Message posted on 10 Jul 2024 02:35 PM
Re: Slow unreliable connection
@HBKHHH Have you changed the default setting in the broadband sheild to see if that fixes your issue with getting to certain apps?
Message posted on 10 Jul 2024 10:53 PM
Message posted on 10 Jul 2024 11:03 PM
@HBKHHH Does it say that you are not in the right region or country?
Message posted on 11 Jul 2024 07:20 AM
@Highlinder nope country and region are it just it just won't load specific sites but then loads everything else fine
